neweuser
neweuser's Avatar
07.05.2006, 09:36 AM
then yes, what i said is correct, it won't allign because the hybrids are a bit different. You would have to put the shafts on first, then put the halves together, if that don't work you will need to get cvds. Are you running stock otherwise? can you send a pic to me? I may have a set that I could let go?
