MetalMan
MetalMan's Avatar
07.05.2006, 10:22 AM
I used a MGT spur gear on a Revo slipper clutch unit for quite a while. If you have a 5mm drill bit, you can bore out 3 of the wholes (triangle pattern) on the slipper clutch plate and the spur gear is a nice tight fit - that doesn't stick out far.
