Thread: More Speed!
07.07.2006, 01:02 AM
The ue has 43 on the spur with 13 on the pinion.
The hb pro gears are 43 on spur 10 on pinion.
Thanks CHC. I've added those diff ratios to my speed calculator and uploaded it.
I just realized that if you use the HB Pro diff along with a typical spur/pinion, you almost don't need a tranny, especially if you set the spur/pinion up right...
