Originally Posted by neweuser
Ok. I ordered the quark today. Does it NEED to be programmed by a PC?
The Quark is fully programmed stand-alone (meaning no PC). All you can program on the BK without a PC is the throttle endpoints and BEC on/off IIRC. You can check out Quarks manual
here.
I forgot; you can program if you have reverse or not on the BL without a PC...
