Thread: Range distance
MetalMan
MetalMan's Avatar
07.07.2006, 08:54 PM
I've had problems with my brushless stuff glitching, even when the the receiver/antenna are both on the opposite side (longitudinally) of the car from the speed control/motor. Whether it's interference from the speed control, bad crystals, a cut-down antenna wire, or interference from something else I'm not sure, but it isn't fun! There was a time when I could get about 100-150ft and at that point it would start glitching, but the range has been getting shorter for me.
If you can get 200ft., then that should be good.
