07.11.2006, 01:42 AM
Thanks...I already have a 5955 and a 5995....
both have the same output at 6.0 volts....Only problem I am having is my right turn is better than the left and I am using the stock revo servo horn and linkage....The Bellcrank is by 3 racing....It looks like the problem is related to the fact the on a revo the servo is mounted at an angle and on the G2R it is vertical.....
And it does not make a difference wether you are using the strobe or not....Gearing goes by numbers....
Right now My gear ration is 20:1.....whats yours.....
SkI
