What is the ratio in the jato trans and diff. No spur gear required.
Well, the transmission has small input gears and larger "idlers" gears which form a ratio. The diff is a little tricky because, as you said, there is no "spur". So, I used the ratio of the tranny output gear and the gear on the diff. I checked it against the gearing chart in the Jato manual and it all works out as long as the Jato diff is used in concert with a Jato tranny. Maybe I'll add a notation to the page to inform users that the Jato parts have to be used together to be accurate.
