Originally Posted by neweuser
That's a lot of info BrianG, very intuitive, but the question still remains. and yes i RTFM, but what is the switch for? Something for programming the controller? then when you turn it off, it saves the prgramming, cool, but do you have to turn it on when you drive? TFM SUCKS! Any who, this is the first time you'll see me get frustrated guys! Only because nothing is in the language of Troy! ARRRRRGGGGG!!!! Also, what are the metal wraps on the wires for? can i remove then?
Lol, calm down before you give yourself a coronary! Simple answer: the switch shuts off the internal controller circuitry. It does not shut off the FETs though so a small amount of current will slowly drain the main batteries. And yes, you need the switch on to drive.
The metal wraps? You mean the ferrite cores? Those are to inhibit RF interference I would assume (they block high frequencies).
