07.16.2006, 03:41 PM
Currently I have an E-maxx with aliminum bulkheads, ss suspension pins, RPM arms and skid plates,MIP cvds in the rear. IAlso have a spooler in the rear. I mostly run 7 cell 3300 nimh packs but also have 6 cell packsMost of these have been replacement parts from the first few months of getting my truck. I have a BK9920 controller and have been looking at getting a Feigao 8xl.I know that I will have to get steel idlers and a different clutch. The RR seams cheaper at first cause with the strobe you have to buy new pinions witch are not to cheap for the 5mm mod 1 espeacially if you haare trying to figure out the correct size to run. If the RR clutch will not hold up to the BL then it would have been a waste of money in the long run. I'm usaually not this cheap but I have not worked in 10 months from my stroke. Now I have to be on a pretty tight budget with my toys. The feigao's are cheaper but do they last. I'm not looking to race I just want to do some bashing knowing that some parts will break or wear out. As you can see from my setup I'm not afraid to drive/crash my truck. I've read that a lot of people end up with the quark 125b after trying out a different esc first. I just didn't want to make that same mistake. My 9920 was a gift, that's why I'm starting out with that one.
So many toys and so little time
