coolhandcountry
coolhandcountry's Avatar
07.18.2006, 10:30 PM
Originally Posted by sjcrss
CHC, good luck trying to spot weld a hardened allen wrench to I think the input gear is cast steel...( don't quote me)..but they are 2 different metals.....you could braze them as long as you used a braxing rod w/ flux around it...and a oxyacetylene torch to do it......
Accually I thought the gear was hardened steel. That is why it don't wear out on the metal idler gears. I have heard of people using them for pinion gears on a metal spur. I got some other fixes if it don't work. I may try it and let you know. If I put a spot on each end of the allen wrench so it don't slide thru is all that is necessary. I don't have a brazing torch. I do have a welder.
