sjcrss
Hyper 7 Erevo Center Diff
sjcrss's Avatar
07.18.2006, 10:37 PM
if your using a mig welder, just take your time and you can actually take a drill bit and drill a little indentation where the pins come out, that way your spot weld has some penetration into the metal.. also don't run the welder to cold....might want it a little on the hot side...if you know what i mean...this way it will be a quick spot, and you should get a good spot weld...
  Send a message via MSN to sjcrss
