jhautz
jhautz's Avatar
07.19.2006, 12:42 AM
If your going for speed runs, Id dump the mechanical brake and save the weight of the servo and the mechanism. Your not gonna be beaking that much anyway so it probably wouldnt add much load to the controller. you just have to make sure the tranny doesnt have a 1 way in it somwhere that would prevent using the electronic brakes.
The wanderer motors of the same size and wind are smaller in diameter. The same internals, without cooling fins around the can. I dont know about the others.
Have you considered the emoli cells. They would make a nice compact brick and save a ton of weight over sub c's. But the lightest option would still be to find a lipo pack that would fit. Its gonna be hard to find them much shorter though if you want larger capacity cells.
to make it...
or break it...
Silent...But Deadly
