07.19.2006, 10:22 AM
The Lehners will run a little cooler than the feigaos. A lot depends on how you use it as well. If your just bashing around, you likely won't have extreme heat with the lesser motors. If you plan on long races on a track, the Lehner "19" series is the answer.
