jhautz
jhautz's Avatar
07.19.2006, 01:03 PM
Originally Posted by JThiessen
To get Revo knuckles/U-joints to fit maxx drive pins you need to grind the relief on the drive pin back further. I found this out last night while I was trying to get my center revo drive shafts to fit the emaxx tranny on the ERevo. I had ground down the end of the drive pin first thinking it was just too long. But after doing that, it still fit the same way. Closer inspection showed that the end of the knuckle was bottoming out at the end of the flat on the pin.
I actually tried that already. The thing is to get it on far enough to line up the holes you have to grind the end of the drive pin and the end of the palstic knuckle. Then when you get it on far enough, the outside diameter of the plastic knuckle starts rubbing on the diff housing. I suppose I could have taken a dremel to the diff housing, but I just figured enough was enough.
From what I was looking at I think the only way to make it work (well) would be to elongate the hole in the steel diff shaft, and that was a little more than I could do with my dremel. :027:
I think I'm just gonna try and pick up some 3.3 diffs one of these days. For now, the revo CVDs are functioning fine, just a little heaver than the sliders.
to make it...
or break it...
Silent...But Deadly
