07.19.2006, 07:53 PM
You can adjust it from 2.2 to 3 volts on manuel.
You can't adjust volts on normal lipo.
I was wondering what the cut off was.
Unless I am doing something wrong.
I know what you are saying. The manual states that the cutoff table is only for the "Lipo Manual" setting, but then goes on to say:
Once you have selected “Manual” from table 3.2-4 and set the cut-off voltage manually, switching the battery type to an automatic cut-off will not automatically change the cut-off voltage. (For example: If you have selected “Manual” and a cut-off voltage of 2.2V, any attempts to change the battery selection to “Li-Poly Normal” or “Li-Poly High” will maintain the cut-off voltage of 2.2V and thus, the cut-off voltage must be reprogrammed).
