Gustav
Gustav's Avatar
07.20.2006, 12:14 AM
I was thinking i should have just used 3.3 diffs because like you say for $10 you can get a new one if you need to.I guess this way i can throw in an 8s lipo setup if i feel like it and not nurse the transmission.
If you're not running tons of power then the stock 3.3 diffs will work out a little lighter,racers often use them for that reason and shimmed correctly they should do fine.
I thought it was only the cases that were different too,if they're sealed that's a bonus.
