A4DTM
07.22.2006, 12:51 AM
If you come up with a way to run the two speed. I would keep the mechanical brakes. It would requre a pinion make with two gears. I have seen a few around. You would have reverse then though. But who needs reverse if you can go 90mph forward.
I'm going to try and keep it as simple as possible.. making my own pinions doesn't follow that rule :)
also, this car has no reverse, and now that I think of it, if I don't lock the 2speed, then there's NO electronic brakes. when the spur spins in reverse, it free spins.. if I hold the spur in one location, the car will still rolls forward.. like a one-way 2speed..
question time!
I'm looking at two different batteries..
#1:
MaxAmps Lipoly 4200HV 5S2P 18.5V Pack = $184.99
* 4200mah Capacity
* 18.5 Volts
* 34mm X 98mm X 62mm
* Rated at 60 Amp Constant Discharge
* Rated at 80 Amp Burst for 10 seconds
* 495 grams
* Comes with Standard Taps
* TP Taps Optional
#2
TrueRC 5S1P 18.5V 4000mAh = $85
* 4000mAh Capacity
* 18.5 Volts
* 27mm X 145mm X 50mm
* Rated at 40 Amp Constant Discharge
* Rated at 60 Amp Burst
* 425 grams
* TP Taps Optional
I'll be running two packs in parallel, so the maxamps would be 120a/160a discharge, the truerc's would be 80a/120a discharge. the truerc's would also have lower cg, and be lighter. Do you guys think 80a constant, 120 burst would be ok? I'm thinking it would, but want your insight.
also, will the ThunderPower TP205 2s-5s balancer work with my 109d's?
if you guys think I'll be ok, I'll go ahead and get the truerc's. then I need a ubec, and li-saver.. anything else I'm missing?
very simple motor mount design completed:
only one other part needs to be designed for a completed conversion.. battery mounts. I've decided to make "trays" that attach to the center of the chassis under where the gas tank was, and span along the sides between the tires.. updates as I get em :)
