07.22.2006, 01:53 AM
Originally Posted by neweuser
Cool, that shold help him. Never had the need. So do you use them really when your running too many Volts?
Actually, diodes are intended to be used like a one-way valve; they only allow current to flow in one direction. However, they drop .7v each, and I use that fact to reduce the voltage. Only do this when the load current is small (<= 1A).
There are other better ways to drop voltage, but they are generally more complex and not as simple to wire up for those who have no electronics knowledge.
