07.22.2006, 05:11 PM
go4gold, All you have to do is go up to the address bar and highlight the whole thing, then copy it (it being the link you want to post), then simply click on the little earth looking think with a chain on the bottom of it. Then just paste the link you copied into it. After you hit ok, it will automatically put it in there for you. If you want to do what Brian did, you can simply type what you want there because when you hit ok, it will put it in there with a certain part of it highlighted. That is the text that shows up. If you need any more help, just ask :).
