07.22.2006, 05:18 PM
Yep. I'd hate to think i bought a BUM motor! Also, in the lehner, if you look inside the screw holes, you can see if it's touching the black plate or not. i have checked this several times, over and over! And, now that i had a chance to open the motor up at full speed(if it could ever get there!), it glitches, like it only goes to a certain rpm and immediately stops! like boom, just like that and kicks the motor wires right out the back of the motor with sparks!!! I'm not saying anymore than i have already, but after 685.00 dollars later, I'm not a very happy camper.
But i will ask this, i stuck a receiver pack in my rx to test the channels, all work fine and the servo is fine. i hooked up my 10xl with the 12020 and it didn't seem to heat up, but before i took out the 1930, it did puff up my capacitors(not to mention fried my ubec too) a tad bit on the 12020. so you guys think the esc will be fine?
