Thread: 1930/10 / 12020
Gustav
Gustav's Avatar
07.22.2006, 06:06 PM
kv is 2090,so that's like 40,000 rpm on 16 cells.The motor would be able to pull alot more unless is seriously stuffed internally,if the bearings sound good and it feels OK,and you don't have more than about 2.5mm of thread into it,and there's no backlash or anything then i very much doubt the motor is the problem.
other than heating up your escs that is,it's a hot motor on 16cells compared to a 10xl,alot faster certainly.
Edit;is it a 12020 warrior or a 20120 micro? i was thinking it's a micro.
