Thread: pinion gears ?
go4gold
mod emaxx
go4gold's Avatar
07.23.2006, 01:59 AM
Mark thanks for the info. I also plan on running in the sand some. The 9 or 10xl should run a little cooler with more torque and run time with less top speed. Where did you get the boots as I will probably need some and the most important question do you like the way they fit/seal? The sand really puts a bad drag on the drive train as you probably already figured out. I spend a lot of time in the sand .Mostly ATV's and my truck when it's not broken.
And now back to squee you're the only one I know that can edit someon elses post. That was pretty funny until I found out that I got punked by a 16 year old.My oldest boy is 16 that is what makes it so bad. Still funny though. Keep it coming. I can handle anything that you can thow out.
So many toys and so little time
