squeeforever
squeeforever's Avatar
07.23.2006, 08:12 PM
Well the internals are IDENTICAL so there both gonna be abough 1800 watts if I remember correctly, and as for RPM's, keep them between 35 and 40k. So basically, which motor you want depends on how many cells. Also, the fewer the cells, typically, the higher KV motor your gonna need, so that will result in a higher amp draw. So choose the wind carefully.
