Thread: Brushless power
BP-Revo
BMW M Power!
BP-Revo's Avatar
07.28.2006, 02:38 AM
What about 16 cells? It would fit perfectly across the battery slots, but then again, the cutouts are off so the cells dont actually drop in! I notice that when I did a test fit, I guess I'll be using some extra zip ties or straps to secure (I got a CF one).
Anyways, Most people here run LT Springs (not the rockers though). Also, the weight distribution is different on the G2R, you will find you need a stiffer front spring than normal. Usually you use a rear springs thats 2 steps up from the front, but with a G2R, you should use a rear thats just 1 step up from front, or even two of the same springs.
