go4gold
mod emaxx
go4gold's Avatar
07.29.2006, 04:21 PM
Superbasher, I would remove the old heat shrink and then heat shrink each individual wire first and heat shrink all three together right were it goes through the motor case.That gives you double protection on your wires. Try testing it in your hands before puttingh it all back together. Simulate a bump on each item to find out exactly which one is having a problem. Let us know from there and we probably can help out some more. Hopefully that fixes your problem and you can start bashing again if you can get back into the garage.lol It sounds like you and I are the only ones that use a stick pack on this forum. With all of the battery bar problems we might be the only smart ones.
Edit: Resolder your motor wires while it is apart. After reading your first thread again that very well could be your problem. Only do one thing at a time so you know what the fix was.It takes a little longer but could save a ton of time in the future if you,or any of us, ever have this problem again. And get yourself a ladder
So many toys and so little time
