You can try the stock gearing, but it would help to get a set of pinions, like this one:
http://www2.towerhobbies.com/cgi-bin...&I=LXEX34&P=ML
That way you can play around with the gearing to find the spot where the temperature of everything will be optimal.
Which battery pack will you be using? If it's anything short of GP3300 cells, you aren't going to get as much performance as the system is capable of providing. The battery feeds the system, and the motor can only put out as much power as the battery gives it.
SH Z-Car, Custom Crawler, 8s Savage,
12s XTM XLB 1/7 buggy,
4wd 4-link rear/IFS Pro4 truck,
Custom Hyper 10 Short Course,
Belt-Drive Mammoth ST 1/8 truggy, 4s 17.5 MM Pro HPI Blitz
