Originally Posted by OldSoldier
Thanks for the reply...but let me change the question just a bit:
What should I order to upgrade the front-center drive shaft given that I'm about to install the FLM Extended chassis and the Feigo 9L Brushless motor with Quark 80 Brushless controller??
You are most likely going to have thermal issues with the quark 80 its a bit small for your application. Even the 125's have thermal issues unless they are run with heatsinks and or fans.
