squeeforever
squeeforever's Avatar
08.03.2006, 06:16 PM
Well how it works is a BL motor has a "sweetspot" as for gearing. If you undergear it the motor will run hot from no load and from a lower amp draw, if you over gear it the motor will run cool but the ESC will run hot because of the added amp draw from the excessive load of being overgeared.
