08.05.2006, 04:26 PM
Do you have the with and with out batteries weight backwards?
I would keep them cells if not. They remove weight more than add.
What about the evo packs? The have a good discharge rating.
Actually no, the batteries I'm using are filled with helium and do reduce the weight. ;)
And now Squee's response post makes sense. I didn't catch that before. Doh!
Seriously: Yeah, the weights are reversed. Are these the EVO cells you are talking about? The GP3300 cells I'm currently using work perfectly fine if a bit heavy.
