MetalMan
MetalMan's Avatar
08.06.2006, 01:09 PM
Do you have a set of pinions? Sometimes experimenting with different numbers of teeth is as better way of finding the ideal gearing that having others tell you what it is.
If you go back to 48p gears, Robinson Racing makes some nice pinion gear sets. BTW, 32p IMO isn't necessary. What's most important is gear mesh and the flexing of the motor plate (if you have the stock plastic tranny).
