GriffinRU
08.15.2006, 10:54 PM
Originally Posted by wheelinarcher
I want to use what I have on hand, so heres what I have. I have 18 GP 3700
and a Dewalt 18v motor. And a Savage .25. What electronic speed controller will handle this? I am also using Futuba tx/rx. Can I use a BL ESC so when I upgrade I will have a compatable ESC?
If you do not need reverse then ESC from the past like TEKIN 420F, 420G2, Marine and NOVAK 828-HV will do the job.
If you need reverse, then as it was mentioned above, here you can find serious ESC for robots.
In the past I was running modified EVX on 18 cells with Dewalt motor without serious problems, but not more then 30A continuos with stock heatsinks.
Artur
P.S. But there will be NO BL future with them!
