Thread: pinions
4wdcanoe
08.17.2006, 02:16 PM
To prevent motor overheating I use 2 sets of integy made coolers (INT-c22379x)
.... You better have one strong tranny. The stocker will explode on that power. They just arent built for it.
answer:
At first I learn of motor/controller sets with
old shumacher club 10 ,no need to last long ;)
and next kyosho RS
The RS has steel diff-gears but it needs metal spur (48dp 75-80th) or same size as 32dp( ???th??)
it has metal Steering Knuckle's too.
Anyway,this car may not see over 15 volts..
Pre-deal is made of used inferno, for real USE. Believe it is needed for full voltage.:eek:
anyway, with 8g spiders-diffs that I already have.
does it need titan pins? else?
