08.23.2006, 03:58 PM
The Excel sheet is exactly what I was hoping for, but could never find. Thanks :)
I'll get some of those housings you linked to. Is there a guide on how to shim the Savage diffs somewhere? I'll pick up the hotbodies parts as well, are they a direct fit?
If I run 20/49 on 14 cells, the truck should be topping out around 40mph. Sounds good, but does it sound realistic? I was running 20/51 on my Emaxx with no problems heat wise. The transmission on my Savage spins very free compared to my Emaxx. Hopefully the runtimes will be similar.
Are the stock shocks much good? Do you think it be possible to move my Integy Maxx shocks over to it with a different shock tower? I quite like these shocks, not had a problem with them.
