coolhandcountry
coolhandcountry's Avatar
08.29.2006, 11:26 AM
If I remember correctly aqwut. Your chassis looks very heavy and beefy.
May all aluminum emaxx with batts is 13.5lbs. The tires are heavy and add some serious weight. I can loose the tires for a few lbs. If you do it
right you should be able to get under the 15 lb mark. If you keep going with a 100 grams here. 100 grams there. After a while you will have a 1000 grams on the truck and don't realize it. I will go with a heavier weight if it
means the truck is stronger. If you take the motor off you loose a few lbs on the truck.
Peace!
Country
Help support the
Rc-Monster
Buy here
