Serum
Serum's Avatar
08.29.2006, 11:28 AM
depending. The thinner the layer, the better. as long as the contact area is optimal.
I would use thermal paste to hook the aluminum to the case and use a thermal pad to connect the fetts to the aluminum spacer.
Now you have got it open, can you please check the voltage on the caps?
