jhautz
jhautz's Avatar
08.29.2006, 09:37 PM
Originally Posted by aqwut
there's no reverse on the airmaster one.. and it's alittle tricky to program and calibrate with a pistol... but it's good for a gas conversion.... since you don't use reverse.... when you do use reverse, the motor does nothing or brake (which doesn't matter) but the servo will brake the vehicle... because I used a cheap tower pro 60amp air esc in my inferno a while ago.. and it worked fine.. just I have to calibrate it every time I change packs...
I get that this would be less han ideal for a car application and I don't intend on on using one.
What I don't get is if the hardware is the same, just programmed with diferent software... Why is it so much cheaper. It just doesn't make sense to me.
to make it...
or break it...
Silent...But Deadly
