neweuser
neweuser's Avatar
08.31.2006, 03:51 PM
So if you want to change heat sinks cux it ain't working well, you're screwed. But when you have it set to what you need, then use the adhesive....that's my plan anyways, and my 8 cents...
Yes that's normal, i've had mine laying around without a heat on it and it has not even come close to dry! But that's compound, not epoxy or adhesive.
compound is not a glue type, it's compound, so it won't dry really.
