MetalMan
MetalMan's Avatar
09.01.2006, 07:02 PM
It's the tranny ratio, and the only other gear ratio is the spur/pinion, so I didn't list tranny/diff ratio. I think it might be better put under the diff ratio, and then you could put a note to select "Direct spur/pinion drive" under tranny ratio.
