Gmaxx Cf Ext Chassis
Mark Fradkin
Rad Frad
Gmaxx Cf Ext Chassis - 09.02.2006, 12:29 PM
Hey guys I have a mostly Supermaxx truck running on a flat aluminum chassis from New Era models. I am considering a GMaxx carbon Fiber extended chassis but am concerned w/ the ground clearance. I have made this thing an all out sand slinger at the beach but want to now make it as light as possible. Does the lowered stance inhibit the ability to get over obsticles.? Usually run pretty high speed, straight line drags. Will the lower CG help in climbing sand hills.? With a RacerX suspension set to a higher (longer, taller) position can there still be a pretty descent tall stance for all -around sand & general bashing.?
Wand 8xl
Spyder8
Quark125
apachee5s dual parallel 3700
RacerX suspension
Thanks Mark
