lipomax
05.01.2005, 09:24 PM
That motor ain't that fast. I'ts only 4200 KV so using 7 cells, you're only getting aobut 32,000 rpm. Using measly 7 cells, a basic 5300 will go faster. A cheap feigao 8s is faster. A Novak SS5800 is comparable... That motor is hardly working with 7 cells. What gearing are you using anyways? What's the tranny ratio? I'll give you some numbers...
