09.04.2006, 10:33 AM
I did manage to tune the lsp for decent steering, but it required pretty strong rear brake bias on a tight track - which is not an option on your truck without a little work(easy enough to do I suppose). I loved the lsp handling otherwise. In contrast, my G2R turns at least 2x as good as my lsp ever did(too much steering almost, which is my preference).
If the front sway bars are still on the truck, take them off. Then, raise the ride height to arms slightly above level(to increase body roll) and run the front a little soft - you can get it turning pretty decent with some setup.
