Batfish
Batfish's Avatar
09.04.2006, 01:49 PM
Can the nomadio run on the spektrum rx? I have them and don't want to go thru the hassle of getting all new rx again.
With the latest beta software from Nomadio, you can use Spektrum receivers, but you need to plug your radio into a computer to make the change to DSM (Nomadio calls it "Da Slow Mode" because Horizon/Spektrum trademarked the 'DSM' acronym). You also need to plug in again when you want to switch back to "Nomadio" mode.
As I mentioned, it's only with their beta software and it's a non-supported configuration, so you're on your own when using it, but several people have posted on Nomadio's forum saying it works just fine.
Joe
Electronics run on smoke... if you let the smoke out, they stop working.
