Originally Posted by neweuser
Either way, it does not look good!!!
True, but at least if it was from the BEC, you at least know that you shouldn't use it anymore since the load is too high. Although, now that I look carefully, I see a little more scorch marks near the top left edge of the picture. What is going on there?
Since the BEC is not on the same layer as the drive FETs, has anyone thought to add a heatsink there?
