09.07.2006, 03:52 PM
Originally Posted by MetalMan
MUCH better :). IMO I think this is the final version. The only problem now is that the theoretical speed of my Rustler is 73mph even though when running it it's only going about 50mph.
Yeah, I forgot to add a note that after around 50ish mph that the top speed will probably be less than the calculated value. I'm sure wind resistance becomes a major factor. I also think terrian is more of a factor at higher speeds as well. Gentle terrain at 30mph becomes rough terrain at 50+ and the resulting jarring affects speed I'm sure.
As to the motor kv values. For the Wanderers, I list the loaded values found in the store. For any Feigao that does not have a Wanderer equivalent, I list the advertised kv from the manufacturer, which is unloaded. I actually would probably prefer to list unloaded values because the loaded values seem like a generic fudge factor to account for weight, gearing, terrain, wind resistance, and/or losses in kv from the amperage draw. This would explain why some people report faster speeds than calculated (Squee). I would like to keep the unloaded or loaded kv consistent across all the motors, but I don't know how the Lehner Basic/XLs, LMTs, Mambas, etc motors are rated. If anyone knows how everything is rated, I will be more than happy to change things to be consistent.
I don't think there will ever be a "final" version. :)
