09.08.2006, 12:03 AM
Actually, as long as you have steel idlers, you should be fine. Coolhand, he wants to keep his stock diffs and tranny, and only cost him 300-350 to go 40-45...but we all know that won't happen. You need some upgrades to go the speeds you want man, and really no way around that. HV Maxx or not! Still need idlers, drive shafts....etc. + you are talking about 40-45 mph??? Not to be rude, but if you read some threads here, you'll soon learn it won't happen without upgrades. If speed don't matter, get the HV and replace things as they go IMO. Otherwise, you are going to spend more $$$$. Last option...save your 350.00 for your system, then later get your upgrades, then think about going 40-45! Just my two cents. But start off with a good BL, maybe a 9920 and a 8-9xl??? depends on cells? You can go BL, but you must understand that upgrades ARE NEEDED. But shop around here, read a lot, then purchase......
