09.08.2006, 10:12 PM
Neweuser, I just sent you a response PM.
And just for others' benefit, the PM went like this:
For your 12v leads, just use the yellow wires found in the harddrive hookup leads and the two yellow wires in the AUX lead (the square plug with just two yellow and two black), and there should be a few yellow largish gauge wires in the motherboard connector. Tie all these yellows together and then tie the same number of black wires together (from the same cables). All the rest of the cables you can cut back and insulate. To make it easier, you can bundle all the orange wires, red wires, and extra black wires together and insulate those as a group. You will be left with several more wires which you should individually insulate. Once it is all done, you'll have something like [I have in the above picture].
