neweuser
neweuser's Avatar
09.09.2006, 09:41 PM
Do you recommend doing both the 5v and 3.3? Or just one or the other with the options you gave ?
The other question i have, is the parallel diagram, do you put two resistors one one red(any) wire, and two on one black(any) wire? Just want to make sure. I was thinking of just removing part of the covering instead of the whole end. Also, do you just connect them to the ends and then from the resister, they go to the board? Nothing on the end but the resistor? is that right?
