09.12.2006, 08:08 AM
Try this....set your radio to factory setup....and then program the controller again, and make sure the motor is programmed for the forwad direction, if the motor still goes backward when you move the throttle forward, just reverse the motor direction, by either switching the 2 outer wires , but im not sure how for the quark
