05.03.2005, 08:33 AM
JOHNNYMAXXIMA
I'm assuming you have the 9918 controllers. I meant reprogramming them. Don't mean to confuse you, but I think if you are using different contollers the speed controllers need to be reprogrammed each time you switch.
I have a schulze so there is no programming, but the warrior controllers needs to be programmed.
patch
Custom extended aluminum chassis; UE idlers; Feigao 10L; 18.97KWF; 16 Matched GP3300; MIP CVD's; Custom rear driveshaft by RC Alloy's. Racer X shocks
