jamesbernatchez
The Brushless Wonder
09.13.2006, 12:30 PM
Originally Posted by Serum
Yes, it will fit a stock e-maxx plate. (25 mm screw distance is used with the Neu as well.
you can adapt the plate to fit the center diff.
:018: Exactly what i wanted to here!!! I was looking at the century Mod 1 gears....any idea what tooth count i should start with? I can do 9, 10, 12, 13, or 14 tooth gears. I will be using the stock LSP spur gear which i think is 50T......i will purchase the kyosho plastic spur from mike(46t i think) later.
I plan on ordering the emaxx motor plate and a few of the century pinions from tower right now. Everything else will be from Mike. What 3 pinions out of those would you get?
Thanks for the help as usual :)
I only have crawlers...finding a brushless project to begin though :)
  Send a message via AIM to jamesbernatchez
